Has anyone heard or know of what could be the cause of the radio staying on when you shut the Ram off and take out the key? I can also turn the radio on without putting the key in the ignition and turning the key to ACC. I thought it was my gauge wires (I put them into the suggested fuse holders, i. e. Ign. and Illum. ), but I pulled the Ignition fuse out and the radio stayed on and I doubt the Illum. fuse would be the problem.
Thanks
Went to the Dealer and they said they have to trace out the problem... gulp!
Got any ideas of what the problem is??
White 2001, 3500, Auto, 4:10,QC,2WD,LB, A-pillar mounted transmission and EGT gauges,34' DBL slide Cardinal 5er (12,600 GVWR)
Thanks
