PIAA Platinum Bulbs.. Any Good??
Running Boards/Box Steps
horton on 1998.5
Thanks Thomas,
I guess I just didn't check close enough. I'll just have to order me a couple of those PIAA bulbs.
I have the same question as someone posted. I have the bright box and wonder if the new bulbs will cause a problem? Any help will be appreciated.
Thanks, Terry #ad
:0 #ad
Terry Tucker, Terre Haute, Indiana, 4 wheel antilock brakes, 99 QC,LB,4X4,5SP,3. 54 LSD,Scott CONE SHAPED K&N, TED JANNETTY 4 IN EXHAUST, PYRO AND BOOST GUAGES, RV INJECTORS, TST PowerMax, Prime-Loc fuel filter system, Rancho 9000 shocks
I'm very surprised at the number of replys that thought the PIAA Platinums were better than stock. Last week I purchased a pair and put ONE in my '98 Ram. I compared the new PIAA with the factory light inside the garage, on the street and in the back country on very dark roads. I sure couldn't say it was any better in fact I thought low beam was worse than the factory one. At $100. Canadian it was an easy choice to return the bulbs for a refund. I'd like to have some real lights that you can see the difference.
'98 2500,4X4,QC,SB,Auto
Lil' Dog, I got them at Cochrane Dodge. I noticed they really are brighter on my truck then the factory bulbs and will add to your visibility. I notice I have less fatigue when driving all night but reading Brian's thread above, he wasn't happy with his... hmmmm I have heard that from a few folks but I did the same kind of test and I could see a huge difference... makes ya wonder. A few of my friends have commented while in my truck now that the road is lit up better and it appears whiter and even asked if I had the hi-beams on.
Also, the bulbs in the Sports with two bulbs per side are not 9004's... I'll get the number tomorrow. The dealer mentioned to me that they are not 9004's but I didn't think to ask for the number... BAD Scott Bad!
SCOTT
Rammin' lit up
Maybe I'll get some green clearance lights for Christmas #ad
Wheres a green face on here?
RAMMIN's best done BOMBed
[This message has been edited by scott1 (edited 11-23-1999). ]
Scott,
The owner's manual for model year 2000 shows 9004's in the sport high beam lamps and 9007's in the low beam lamps.
Thomas
The last time I checked the 9007 weren't out yoet in the PIAA's. That is the same bulb used in the durango.
96 Long bed EC, Banks Twin Ram, BD TC, BD EB, BD VB, Mag Hytec Pans, Warn 8000# winch, TJM Bull Bar, Speedliner, Katzkin Leather kit, K&N Filter, Trailmaster 2" Lift, 35BFG ATKO's, Kodiak Sidewinder Steps, Reflexion Cowl Hood, Autometer Guages, Horton Clutch Fan, PIAA Superwhites.
Wade, I'm not real sure but. . I was told by a co-worker who owns a Durango that PIAA just released the Platinum Super White bulbs for his application. Those of you that require the 9007s may want to double check this.
I have had my PIAA Super Whites installed for a year now. They are not much brighter than OE, just EXCEPTIONALLY whiter! I love 'em!
'98. 5 2500 QC 4x4, (Black) SLT Sport, personalized license plate: BLCKOUT, ISB, LWB, 3. 54 LSD, A/T, 275 hp. injectors, Glasstite Vision II "canopy", Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, VDO Vision gauges, PIAA Dual Sport 900 auxiliary lights and Super White bulbs, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, and Banks 3. 5" dia. exhaust.
COMING ATTRACTIONS: Banks (ISB) Stinger 4" dia. stainless steel exhaust system!
SVP of BOMB! heh,heh,heh
Thanks, I'll have to check. It's been about three months since I went through the Headlight phase. You understand, get em, got em, love em, what;s next.
I have been using the Britebox with normal lamps. It works well. I tried with some extra brite lamps I got at checker at one of them exploded in a short period of time ,
making a bad mess.
I think Brite-Box tells you not to use anything hi-powered in them.
Rich, They are probably over-wattage and "for off road use only". "Blue" light bulbs are generally not D. O. T approved [Illegal] #ad
1994 Dodge Ram SLT Cummins 5 speed 4x4,3. 54 gears, Scotty Air System,PIAA Platnum Super Whites,Optima red top batteries, manual trans filter,Turbo&Exhaust blanket,Magnaguard rear diff cover,Edelbrock IAS shocks,muffler removed,Borgeson steering shaft,Trailmaster steering stabilizers,Rancho upper & lower links,Polyurethane sway bar bushings,Skyjacker 2" leveling springs(front),Fabritech Stage II Traction Bars,Denman Coyote A/P LT305/85R16(36" Tall) tires on Stock Dodge Chrome 16x6. 5 wheels,Bushwacker Street Flares,Back-off saftey brake light,Bugflector II bug shield, Royal Purple ,Amsoil& Red line lubes throughout.
1970 Plymouth Cuda (under construction)
1968 Hurst HEMI® Dart , Nah its just a screen name ;-)
