Attention: TDR Forum Junkies You don’t have a crank sensor. Cam sensor is below the injection pump.
Good point. It is possible to hotwire the vp44 (run it without an ECM/PCM). It will only idle but you'll know if the engine and fuel system is working. See Blue Chip Diesel VP44 Diagnostics for details.View attachment 136278
The more I think about this, the more I think your problem may or may not be related to the accident / accident repairs. Could be that the PCM (or related connectors) were disconnected and the ignition key was switched on while they were disconnected with resulting codes set.
- John
I am at this time sitting at a stop light in Rockford Illinois. Truck was running fine, I Pulled up to a stop light and it died.
It's turning over fine and with full pedal it tries to fire. Fuel gauge shows 15 lbs.
,I have zero fuel pressure showing on external gauge. I can hear the lift pump running
I had just pulled away from filling the tank so it is not the fuel level.
The above is your first post on January 1st - 15 psi fuel pressure. Below, today, January 10th, you posted,
I am starting to become a bit confused. Do you have fuel pressure or do you not have fuel pressure?
Are you referring to the day you first posted? My understanding is that the engine has not run since the day it died at the stop light (January 1st). Is this correct?
- John
I still think it’s got to be something the body shop inadvertently did. Did they have the bed off? Cab off? Have you tried leaving the fuel cap off? Visually inspect every inch of every fuel and vent line.
Bingo!I got up the next day, filled the tank, traveled about an 1/8 mile and the truck died. It would not restart.
Gary
I had the receipt in the truck. I have never came close to doing that in the 4 years I have had this truck. I drove right up to my favorite unleaded pump and filled her up.Oh crap John. You called it. I have been driving a gasser so long, I put 19 gallons of gas in the truck. Oh Crap. What do I do about that Boys?
