After a 13. 5k mi. break-in period (using Valvoline/Cummins Premium Blue), I tried Red Line 15W-40 synthetic... it worked OK however, I thought my oil analyses should have been better... especially considering the cost per quart. I used this oil for around 27k mi. , changing it at an average interval of 6. 7k (with the intention of stretching this to 10k IF oil analysis supported this. . which it didn't).
Switched to Valvoline/Cummins 15W-40 Premium Blue 2000 semi-synthetic... had it in for only 2k mi. (I switched it out after reading data that I didn't particularly care for pertaining to this oil).
Switched to Amsoil 15W-40 HDD&M synthetic... worked VERY well and much cheaper than Red Line. It also provided me with the best oil analysis report. . to that date...
I became an Amsoil "dealer" (to purchase the products cheaper) and switched to their Series 5W-30 HDD synthetic... AWESOME! I received by far, the best oil analysis to date!
I'm staying with the Series 3000... although, I've always wondered about the Royal Purple (I've heard it is an excellent quality synthetic).
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, next gen. (heated) Power Vision mirrors, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, "special" Brite-Box, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram and 14 cm2 (wastegated) turbine housing, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
COMING ATTRACTIONS: break out those sun glasses! Plus, BLACKOUT gets a "BIG GULP"
NRA Life (Patron) member
[This message has been edited by John (edited 05-28-2001). ]
