poly bushings for front end.
Factory Fog Light Switch
Anyone got > 200k miles on a 12 valve?
Anyone have any experience with poly bushings on front end (4x4). Where did you get them and did they improve performance.
1996-3500 tst stage 3 plate, K&N air filter,4" exhaust,bigger injectors,b&m trans pan,Amsoil all around,temp gauges out the wazzo,much trans work,double tow 33' 5th wheel and 12' trailer w/motorcycle(Honda Valkyarie Interstate)Also have 1999-2500-stock.
Bill,
My front sway bar has Energy Suspension bushings. Both bar & Endlinks.
Upper & lower control(4x4) arms are Rancho aftermarket links with polyurethane bushings on both ends.
The truck tracks straighter and handles much better with both upgrades.
Polyurethane is the ONLY way to go. #ad
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust,Autometer Pyro & Boost gauges, Bosch 215HP injectors, Timing @ 14. 7 BTDC, JRE Stage III #4 plate 270/675, AFC spring kit,Pschotty Air, Optima Red Tops, Geno`s Exhaust Blanket, Synthetic lubes throughout.
HEMIDart - Were the sway bar bushings easy to install? Last time I swapped rubber for poly was in 1977. The bushing bracket bolts were a pain to get back in. Where did you get the parts? Thanks for the info #ad
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
Dane, I got the swaybar kit from Energy Suspension. These are top quality. They give you new bar brackets that are greaseable. The full kit includes the endlink pucks.
Installation is simple. The endlinks are the hardest, but still a piece of cake. Measure the OD of your swaybar, to get the correct kit. #ad
Part #`s here: See the footnote page too. http://www.energysuspension.com/dgt1.html
You may need to call Energy Suspension for the correct Part #`s to fit your 2001. The webpage is a little old.
[This message has been edited by HEMI®Dart (edited 09-16-2000). ]
