Popped out of Drive?
Install fuel tank where the exhaust resides
Blowing Fuses
While driving tonight,I was crossing into a driveway going about 15-20 mph and didnt realize how steep it was when i almost hit my head on the roof and lost my fillings, After i re-grouped i stepped on the Fuel peddle and RRRRRRRRMMMMMMMM RRRRRRRRRMMMMM... damn thing popped into Neutral ... i said WTF ... . anyone esle experiance this???? . . JB
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors and boost module,HX-40 16cm,here and waiting to be installed, Next Jet-hot my ATS exhaust manifold and turbo housing, and special thanx to rob for swaying me on a 4 wire Blue Box(incoming)
I noticed that if I'm in sand with my truck and it hops a lot it'll go into neutral if it's in drive... So I just put it in second and lock it in 4wd... And it doesn't happen too easily, it has to hop quite a bit which probably isn't too good anyways, but it's hard to back off of that sweet sounding cummins power. #ad
