Posi rear axle
Seat belt warning chime
Air Conditioner Compressor
AAM... a planetary gear limited-slip is an option on all the 3rd Gen trucks. There have been some complaints about this factory limited-slip but I found mine to be VERY positive, works quite well! There is also an electric locker for the front differential, Power wagon style are availble from the aftermarket and I think ARB has a air locker that will work in the front.
My truck has 56k miles on it and the carrier is junk. For some reason the truck has had a bunch of oil leaks. Today I was changing the left rear wheel seal. It looked great except for the some metal filings. So when I was done I puled the rear end cover. The posi is junk The worm gears chipped and lose. The posi is also useless in snow. In mud or sand it worked fine. I would like something better.
03 2500 xc 2wd auto 354 251k
04. 5 3500 cc 4wd drw 6speed 373 56k
