my turn to chime in ... . WWWWWWWWWWWWWWWWEEEEEEEEEEEEEEEEEEEEE !!!!!!!!!!!! , my edge came today at 1 pm , i went out a little after 5pm to do the install , at 6:45 i was finished . i also read directions badly , i figured out how to change settings , but missed on how to turn it on .
so my first couple of blasts saw boost levels close to my VA and 275's with the redneck boost module ,which was 34 ( after i fixed my intake leak ) with the edge , and no VA i was seeing 30 with a spike to 32 , this was with the unit turned off , when i finally figured out it was possible to change settings without turning the unit on ... HOLD ON HANNA !!!!! .
( also note , i would like to see a better way to look at it while driving , its dangerous at warp speed looking down to make the change ... in traffic
when i figured out i didn't have it on , i was on level 3 ... oh by the way i'm sporting a HOT #3 ... and i thought i was going to spin the needle off the gauge ... i saw 40 psi , good thing mine goes to 50 ... anyway now were having fun , by my seat o' the pants meter , #1 is better than the VA , and it keeps getting better as you go up ... and # 3 scares me ... . with my straight thru 4" system i am now louder than a straight piped harley
and it picks up speed in a hurry , i did note when on the highway this evening that where i would labor a bit to hit 105 mph ... not anymore , but i also see my EGT climb almost as fast as my boost ... when i hit 1250 i backed off ...
then when i got off at my exit and popped it out of OD , when i started to accelerate some i stumbled , and it was harsh , hasn't done it since , plus i had a check engine light on , it has gone out , and i haven't felt the stumble again , but i did have my cruise set prior to this while at level 2 and also noted no surge in cruise control on #2 ...
other than that this thing is AWESOME , haven't dared try it with the VA , but i loaned that to a fellow board member to test out tonite so that will have to wait , but i don't need it ...
sorry for the novel , all in all this is an excellent product , but i think i need a bigger turbo to keep my EGT's in check ...
edit ... kat they finally fixed it so we can delete our own posts ... no more seeing double ... you can axe your post below to save all important server space ...
John W.
[This message has been edited by Mopar-muscle (edited 07-01-2000). ]
John W.
