This morning I woke to 15 deg weather. When I started the truck the power steering pump howled everytime I turned the wheel,, I did check the fluid levels - everything seems fine and this noise went away after things warmed up a bit so I am assuming this is just normal when everything is cold. . Prior to this I did not notice this happening but it hasn't been 15 deg around here in Virginia either. . Just a query - I don't believe its a problem. . Just wondered if anyone else experenced this.
