Hello
So I replaced my power steering pump because it was leaking from the shaft. I replaced it with a new assembly that came with the pump, reservoir, and pully. I did the bleed as per the manual and used atf+4 fluid. I had to bleed the system in other occasions because of changing parts and never had any problems with it. So I’m getting a weird leak. It seems to be coming out of the cap but not all the time. I drive it to work about 10 miles away and it doesn’t leak, but when I go on a long trip there is fluid coming out and running all over the reservoir. I stopped and checked the fluid right away after stopping and it is not over full or foaming. I don’t hear any whining pump noise so it’s weird to me. Could it be just a bad cap. I believe the pump is an aae pump. This is an 03 3500 diesel nv5600. Obviously you can’t get an over full without air doing it and I don’t believe the fluid would steam out but I’m kinda at a loss unless a seal is not sealing well and leaking air in at high rpm’s.
