2nd Gen Non-Engine/Transmission power steering pump
Engine/Transmission (1994 - 1998) Cummins VS Duramax
2nd Gen Non-Engine/Transmission power steering cooler
during cold weather the fluid in the power steering pump foams out of the cap. No power steering or brakes. Any ideas on why and how to fix?
What brand of fluid did you use? I've always had good luck using store brand power steering fluid, but recently had to stay away from what my local Napa carries. It's not Napa brand and I will have to edit the actual brand name in later, but it seems to be too thick and it doesn't flow well at lower temps. I don't have any trouble with regular fluid here in the south, but if you have extremely low temps where you are, then the synthetic is the way to go.
The only real cause I can think of is pump cavitation which would be caused by too thick or too low level. Let it sit overnight and check the oil level.
