Pressure port on 24 valve
Fuel line upgrade question? Should the return line be BOMBED?
Snow Plow Prep Group -- Adjustable Springs?
No, I am talking about the plug in the intake pressure port.
1999 2500 ST LB 4X4 Metallic Red, 5-speed, 3. 54 gears, LSD, camper and tow package
Mike, take that rig for a ride around town and let everything warm up, then try to remove the plug and it should come right out. Mine came out almost too easily using this method.
Scott W
Scott,
That did the trick!! It came right out. Thanks for the help.
H E L P ... .....
I am trying to get the 3/4 pipe plug out of the pressure port on my 24 valve engine. I am using a 1/2 drive and extension, but I can't seem to get it to brake loose #ad
. Does anyone have any suggestions?
Glad to hear that worked for you. Not my idea, I learned it from here before I removed mine. I was all set with a 1/2" breaker bar, etc. , placed the 1/2 drive in the boost plug and spun her out with two fingers worth of pressure. Can't beat the TDR for the wealth of experience, best $35. 00 bucks I ever spent #ad
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Are you talking about the plugs for the coolant? Maybe try warming the engine up first.
2001 Quad Cab Dually, ETH, SLT Plus, Isspro Pyro & 50lb Boost, 275 injectors, Banks Power Pack FINALLY :D.
Tried that myself, but to no avail. I twisted off the end of a 1/2 inch drive extension trying to break mine loose. I drilled and tapped the intake manifold tonight to get my boost readings.
Morph.
'99 2500 4x4 QC Std transmission, Purple (usually Mud Red), 10 Disc Changer, 285x75Rx16 BFG Mudders, Amr. Racing Baja Wheels, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper packages. DDIII's, Exhaust, TTPM, Boost Module. Fuel Pressure, EGT adn Boost Guages. Mallory Fuel Pump. (fastest farm truck around). And can't forget the hydraulic PigSticker.
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer, 2 horse bumper pull, Round bale Trailer.
1960 Farmal 340 Diesel Tractor.
You guys are making me nervous. I am planning on installing my gauges today. Since it's warmer here in Ohio than it has been for a while. I have a Snap-on 1/2" pipe plug socket that is designed for removing square pipe plugs. It is tapered slightly and doesn't have the locking ball like a 1/2" extention does, which makes the socket stonger. I figure with my 24" Snap-on breaker bar and the special socket, it will come out one way or another !!!
Charlie
2001. 5 3500 Quad Cab 4X2
HO, 6 spd, 3. 55AS, Jacob's brake, patriot blue, 22K Reese 5th wheel,Reese digital brake controller, Isspro pyro & boost gauges, Snap-On tool box
Good job Morphious, the intake manifold (runner) is a better boost source location anyway.
Gauge installation was sucessful. The 3/4 pipe plug in the intake came out easy. Probably had 20-25 ft/lbs torque.
Charlie
