"Prototype" Super Phat Shaft 62!!!
WHat causes this to happen?
New to Dodge - What chip should I buy?
JStieger
Wow... just wow!
This is a continuation of this thread
Background:
I explained the 66 surging issue I had to Brady and Shane as well as the fact that I wanted something that would suit my driving style better - a turbo that was not for all out horsepower, drag racing, or sled pulling, but yet allowed me to have fun in town and towing as well as random acts of "pouring-the-coals-to-her". Subsequently, I enquired if I could just keep my SPS turbo, but change just the compressor wheel and housing since I had a very stout turbo platform that has already been paid for.
They did express some concern though that the custom 14 cm2 exhaust side of the SPS 66 would "overdrive" the 62 mm wheel as well as the fact they haven't tried this configuration on any of their own personal trucks yet and were reluctant to have me be the guineau pig 250 miles away.
Another idea was to just swap my SPS 66 for a regular PS 62 with a more "laid-back" 14 cm2 exhaust, but we soon realized that I had a different exhaust flange (flared HTB2 style), as opposed to their normally sold turbos, that was machined onto my SPS 66 specifically for my downpipe. After some more discussion, I volunteered that I keep my wastegate set at 40 psi anyway so that it would do what it is supposed to do while retaining some factor of safety for overshooting the wastegate. After this was said, it became a "no-brainer" and we agreed to go this route! We would never know until we tried...
Turbo Re-work:
My SPS 66 was completely torn apart, cleaned, and inspected. Nothing wrong was found. After wheel balancing checks, a brand new 62 mm extended tip compressor wheel and matching housing were installed onto my already stout SPS platform.
Results versus SPS 66:
-my low end grunt is back with no surging or barking!
-empty cruise boost increased by 1-2 psi overall
-empty cruise EGT decreased by 100-150*
-off-idle smoke as well as low boost smoke duration significantly decreased and cleans up quickly
-hot-rodding around town and the interstates show boost versus drive pressure is essentially 1:1 up to when my wastegate opened at 40 psi. From 10 psi to 40 psi, the boost is on average 1 psi greater than drive pressure. Right after 40-42 psi, drive pressure dropped to ~10 psi after the wastegate opened.
-In terms of "spool-up feel", the top end slam-you-back-in-the-seat is slightly reduced, BUT this feeling is occuring about 150-200 rpm lower than the SPS 66. This SPS 62 turbo also hits 10 psi sooner than the SPS 66 so current owners of the SPS 66 can only imagine what this feels like!
-The "spool-up feel" is not touchy either. I rolled into the throttle at all speeds on some big hills for a load and in no way did the boost rise get out of hand. It was very much controllable.
-highest top end EGT I hit so far was 1300* with the TST twins on 3x2, MP8 on 40%, 100 HP injectors. As soon as 40 psi was hit, the wastegate opened and the EGT dropped 200-300* and I held this until redline @ 108 mph. Once I get some more miles on it, I'll turn up the TST some more. Note the most I've turned the TST up to is 4x4 in my configuration because it is so violent that it freaks me out sometimes...
Closing Thoughts:
Although I admit it was a bit frustrating trying to get a hold of Shane and Brady earlier this week due to their extremely busy schedules and everyone wanting everything from them RIGHT NOW, the early frustration has totally paid off in me having a turbo configuration that more suits my needs because they LISTENED to what MY NEEDS were. The final test is towing of course, but judging from my empty experience so far I believe I will not be disappointed.
Judging by comments after taking Brady and Shane for a ride, this turbo will probably not be a "prototype" anymore soon... :-laf :D (they said they still need to test it in their own personal trucks that don't have cams, injectors, manual versus auto, etc... )
I hope to get some dyno time in January as well as some tow time. I'll just post the results of these events on this thread. I'm expecting less HP due to less air from the smaller 62 wheel, but I also expect torque to slightly increase due to the turbo spooling earlier/quicker.
darn, I was just beginning to really like my 66 too. .
hmmm, a sps 62 does sound very interesting.
Great post, please keep us apprised of the outcome and soon to be dyno'd results. .
NOTE, I just read that microsoft has been unable to sell any more MS Word programs. Something about a shortage of the letters S and P.
Must be something to do with all the Pre Prototype Super Phat Shaft turbos now being offered for sale... (PPSPS)
JStieger, I was talking to Shane and Brady the other day when I called to order a Hot Rod VP and a turbo for my truck.
I was pickin' his brain about what would be best for me, and he said that somebody on this board was doing some experimentation. I guess he meant you.
After he mentioned your surging problem I went with the 64. So thanks for sharing the info with him/us.
They made a good impression with me. They obviously care about their customers.
SPS 62 boost versus drive pressure
Well after driving around for a bit I collected some numbers and graphed them below. I think the numbers speak for themselves! For all numbers I tried to roll into the throttle, which is easier said than done with 100 HP injectors plus TST "twins" program on 3x2 :-laf . For these #'s I figure I was running around the 440-450 rwHP level based on previous dynos. All #'s were recorded at 5,000 to 5,500 feet elevation.
This turbo builds boost so quickly and gets way ahead of the drive pressure - it's already making 40 psi boost when the drive pressure is at 36 psi without hearing the wastegate open and the smoke clears up quick. EGT tops about 1300* from the TST low boost fueling and settles around 1150*before I run out of speedometer and road. So for all intents and purposes this turbo is 1:1 boost versus drive or slightly better (tested up to 40 psi wastegate setting). However, if I matted the throttle, boost would hit 44 psi & EGT about 1400*, the wastegate would slam open and then drive pressure would be ~20-30 psi on the SPA gauge due to bleeding off the exhaust through the wastegate.
I believe the key to this turbo being successful due to the big, custom machined exhaust side is to use the wastegate so that the turbo is not oversped. I am pretty content with the 40 psi wastegate setting and don't want to try to crank it up any further in order to maintain a factor of safety. I still haven't towed with this yet as the weather has been crappy. I'm hoping to dyno this by the end of January 06.
Yep, you just convinced me I need one along with the TST. The wife is definitely gonna be unhappy next month. :( :-laf
Going in for this upgrade tomorrow morning at Industrial Injection. My Phat Shaft 62 rocks and the Super Phat Shaft 62 only promises to be better
I ordered one on Monday from Shane. I also talked to Brett and Brady this week. From what they all explained to me this PS 62 Super will Rock !! on the 3rd gens. I really hope so . I hope to see 50 psi boost and low egts without surge and barking. Will be posting outcome very soon as the turbo should be coming in in the next day or so
Ive got that " Super Phat Shaft Fever" > Look out Stock Power stroke and Duramax. Im cummin !!
What would be the advantages/disadvantages of the sps62 over the ps62??? and what would be the physical differences between the two?
Kevin
Which twins program are you running, the 12psi or the 24psi? This sounds a lot more along the lines of what I want, opposed to a 66/14. I have an HTB2 62/12 right now and temps climb pretty fast, especially at high altitudes.
Any prices announced yet?
My sps 66 with a edge hot box and stacked with an EZ pressure box, running max settings on both never gets over 1400. When the boost comes in, you can see the temps fall pretty quick. Whether the 62 or the 66 psp, its a piece of art work. You can't go wrong with either.
I have the one called "03 twins program". It fuels way hard down low. I had another TST early last year with the regular program and it ran like dog poo on my truck with all kinds of weird stuff, the least of which was being a code monster. My turbo evolution has gone from stock -> HTB2 62/12 -> HTB2 62/14 -> SPS 66/14 -> SPS 62/14. I'm at 5,000 to 6,000 ft elevation too.
I still haven't dynoed or towed with it yet. Once work settles down after the "friendly takeover" is done I should be able to go dyno. One of my friends is moving in the next few weeks so I should be able to get some towing in then.
I think with your combo of injectors and box plus heavy towing this turbo will be the ticket!
TX Gooseneck said:
How bad does yours smoke down low? There are times I love the smoke, but times it can be a bit annoying, does yours clear up quick?
With the SPS 62 if I leave the TST and/or pressure box on low settings, then very minimal smoke - maybe a light gray haze that clears up quick. If I mat it under low boost, then of course I get the little black cloud that still clears up quick.
With the SPS 66 it was a constant haze/stream/wisp of black smoke when cruising that only cleared up when getting on the boost. It was even worse when towing. The SPS 66 based on my record keeping cost me about 0. 5-1 mpg because of this.
At night with same low TST and/or pressure box settings with the SPS 66 there was a constant cloud that kept on fogging the people behind me - even on the interstate, but with the SPS 62 I can see cars behind me fairly well.
I agree with the smoke being annoying at times when driving in traffic as well as seeing the $$ go out the pipe!
Just finished the install of my sps 62 over the weekend. What is sad is that I do not know what my boost is b/c this thing slap pegs my 35psi gauge.
