It's not necessary to pull the console to change the bulb. To gain access to the bulb you can remove the lens that is pushed to turn on the lamp. The lens is held in place with a latch tab at the center of its curved, outboard end & two pivot tabs on the inboard edge.dclassens said:... how does this console come of the roof?
Sure sounds like a complicated & costly way to change the 906 bulb: http://www.topbulb.com/find/Product_Description. asp?intProductID=42983.Jong said:You do have to remove the console to fix this- I just fixed it on mine. You have to order a new set of switches from a dealer (~$36)...
