Engine/Transmission (1998.5 - 2002) pyro tap ats
Engine/Transmission (1994 - 1998) Head stud torque @ gasket thickness ?s
2nd Gen Non-Engine/Transmission Wheels and simulators questions
Some are, some aren't. I think its an option but I could be wrong.
The best place to tap it is in the rear runner (volute) about 1. 5" or so from the turbo flange.
make sure you don't tap it all the way through, just one or two threads for the pyro.
If you go all the way the probe can bottom out and you will have sealing problems.
Anyone have better instructions?!? I don't know for sure if the best place to tap an ATS is different from the OEM manifold.
Hope that helps,
-R. J.
Tap it down till you have 7 threads left on top of the tap,You can count down 7 threads and put a pc. of tape on it for depth... .
"If you have access to a drill press, it would be a good idea to use it! The manifold is very thick at that point"
interesting..... the stock ones cut like butter
ats/pyro
Mr. Cummins02. . Do a search and find a picture of where the pyro goes, I don't remember the measurement, but it goes in the center of the rear manifold outlet above the turbo. It will be a lot easier to drill and tap the manifold before installing the manifold as the manifold is pretty thick at that point. You probly already had that figured out. The metal isn't hard but it looks about like it's 3/4" thick, by my old eyes. In May I installed my ATS and used studs and nuts instead of the stock bolts, makes installation much easier. The parts run about $30. There are a lot of posts on the subject,including mine. I suggest reading them and deciding on how you want to do it. It would be best to read up on the installation by someone who's done it!!!!
There's a post on this page by Thomas Trujillo, look thru it and you'll see where the probe goes!
thanks for all the info will definetly tap befor installing, where can I get the studs jdooner? I'm not to worried about the ease of installation but thanks for the concern. exhaust manifold and all that room not to worried. let me know about the studs I would like to go that route.
i got my stuff from http://www.reidtool.com/. here is the list i got right or wrong? i did not instal them yet,ew-40 3/8 stamped flat washers( dont know if im going to use them or not),fnc-25 m10 colar nut, nl-4 pair 3/8 id vibration proof washers,sus-330 m10 x50 mm setup stud, i got 12 of each came to 59. 01 with shipping.
If you do a search. . type in "ats manifold install' , you'll find a lot of information on this installation. I'm don't really know how move these posts around, I tried and got it wrong.
