Quad Commander on 6.7
ATS compound turbo AFE air filter?
Manual Transmission coolers that work great
Does anyone know if my Quadzilla Commander on my 5. 9 will switch right over to a 6. 7? Are the output locations going to be the same. Instead of oil temp (on the G56) I would rather read the transmission temp since this one will more than likely be an auto.
Thanks
Yes it will work but, you need to make sure you have the latest update so that the 6. 7L is in the menu options when you set it up. Just go to the website and download it.
The transmission temp is a little tricky because of the size of the oil temp port but, that is a good choice!
Thanks! I appreciate it. I emailed your support and got a reply from Justin yesterday with info and prices since I left my pyro thermocouple and temp sender in my old truck.
Tell Justin thanks!
