I have read everything I can here and else where before starting the project. The problem I have is pushing out the hub. I'm using an 18mm deep well socket with extensions and I larger socket turned around on the other end for increased surface area to push against. I also am pushing against the axle tube itself.
Thinking about purchasing the Snap-on tool for this? Maybe the length of extension is hindering the removal process.
Any insight from experienced members would be helpful.
Shane
Springs pa
03 dodge 1 ton duel rear wheel 4wd
Shane
Springs pa
