It gets cold here sometimes. I have started at fifteen below no problem with the regular cycle. No problem at all. I do plug in the block heater but only because it comes up to temp quicker (and makes my wife happy when truck warm right away).
I have seen 4BT and 6BT powered construction equipment as new as 06ish With no grid heaters and they start just fine in below zero weather. As you said, they are primarily there to aid in combustion for emissions purpose, once Cummins went to the 6.7 and DPF grid heaters came along also.
Grid heaters have been a part of these trucks sence 1989.
Construction equipment that I have seen and used that have the 4BT and the 6BT have the grid heaters. Usually you have to turn the key to on and then push the key in for 10-20 seconds and then start. The light for the heaters will glow on the dash when the key is pushed in.
Thanks for the response. By turn Key on. Do you mean hold it in the start position? Or Bump it to start and back to run and wait?
I usually will cycle mine twice when it gets down to 0 degs or colder. But, with the push button start, it is hard to catch in order to do that.
The ECM is programmed to run the grid heater longer when it's colder out. There isn't a need for dual cycling.
My understanding is the ECM will run the grid heater even after starting if needed?
Don't over think this. I'll pipe in from Northern Ontario, where temperatures can regularly get down to -30C/-22F for weeks at a time. -40C/-40F is also not uncommon. I've never in 6 1/2 years had a cold start issue. Use the remote start, and let the grid heater do it's job. The truck will idle up soon after start and the grid heater likely cycle several times for the first few minutes. My general rule of thumb, is that I plug in if the forecast temp is below -18C/0F. I also run synthetic 15W-40 year round. Anti-gel for that American blended fuel is a must if you ever head north of the border.
Interesting. About the 15w-40 in Canada winters. I decided to go with a mix of 15w-40 &5w-40. And I won't be getting anywhere near Canada. I guess I thought the 5w-40 would help protect during cold starts where engine wear occurs the fastest. And the 15w-40 would be best (protect the best) for the long driving days while engine is hot
