Engine/Transmission (1994 - 1998) Radiator drain leak- help
2nd Gen Non-Engine/Transmission Whitch air lift system to buy......
Engine/Transmission (1998.5 - 2002) Need a 24 valve Head
Anyone know how to fix the radiator drain plug? It began leaking after I removed it to change the coolant. Just replace the O ring or the entire plug? Thanks in advance.
Anthony
The o ring may do the trick
You can get the O-ring at NAPA. The whole plug can also be purchased at Dodge for sure and I think someone posted that NAPA has them too. Every time I get ready to drain and flush the coolant I buy a new plug and just be done with it. Ken Irwin
