Engine/Transmission (1998.5 - 2002) Ran fine yesterday?
Engine/Transmission (1998.5 - 2002) Vacuum line?
2nd Gen Non-Engine/Transmission Seat belts
No power today. get's you there and back but grandma style. Reset apps by disconecting battries and leave key on over night or am I buying another TPS? HELP!:eek:
Codes if any?
When resetting the APPS you also have to turn the key to run (without starting) after reconnecting the batteries and slowly press the throttle pedal to the floor and slowly release.
Codes if any?
Yes sir, I know :) Thank's though. I also have it in run position to drain any juice that might be left after unhooking battery's.
Sounds like it's in limp mode.
Check for codes.
Will do. Soon as I get battery's re-connected and set apps. Been searching on checking codes but not finding. I think is turn key of then on then off then on. Do i count the blinks or are they actually given?
Think that's for abs. Took truck out and now I will have power then not then power. Computer relearn? Maybe I will disconnect grounds again for hour unless it comes out of it soon. I screwed up and left key on while reconnecting. So is it just one pedal stroke to reset apps or 3 pedal strokes. Read 3 some where but may be for different year.
