Engine/Transmission (1994 - 1998) RE into RH ?
Engine/Transmission (1994 - 1998) Auto Trans Problems
ok... can a 47re be swaped into a 47 rh?
What I really need to know is can a 47RE be made to work in place of a 47 RH?
What would have to be changed on the RE to make it work... . valve body ??
jim
The difference between the transmissions is the governor. The RH is mechanical and the RE is electrical. The drive shaft is probably shorter on the RE because the transmission tail shaft is shorter. No mechanical governor in the tailshaft housing for the RE. I don't know if the mounts are different or not. They look the same, but I have not done any measurements. The 4X4 shift rod may be a different length. The front drive shaft may be longer.
If you manage to get the RE mounted then you have a problem with the electrical hook up. The RH has a three wire connector. The RE has 10. The RE requires a PCM that is different than the one for the RH so you will need one of those from a '96. I have no idea what sort of difficulties you would run into trying to adapt a '96 PCM to your truck.
ok... back to the top after thinking up more questions.
is it possible to take a RE trans and swap parts to it from a RH and make an RH out of it??
because to make a good rebuild out of a RH you should get the steel planitary and such that come on a RE.
Dumb question probably :/
jim
:confused:
Do you mean turn a RH into a RE? The problems listed by Joe would be the same.
You can get a modified aftermarket RH. Can have it built for about as much power as you want, to a point.
