In all the years of barking my knuckles working on cars and trucks I've never seen anything like this.
I was putting new pads on my 2001. 5, did the front first they were worn down to about 3/32 left. Went to the rears and they looked to have plenty of pad left. This is the second set of pads on the fronts and the factory original pads on the rears. So I looked at the rear pads again and thought what the heck I might as well change them anyway. My wife always says "did you really need to fix that", impling I have_ _ _ _ with it itis. I do!!!
When I pulled the caliper off the friction material came off from the piston side pad. The piston side pad looked rusted and the bond between metal and friction material was gone it just flaked off in my hands! The other side was the same, the piston side pad just flaked apart.
I've never seen this happen before, I feel lucky that I deceided to go ahead and change them out even if they appeared to have plenty of pad left.
It would have been an ugly situation especially when towing.
My lesson learned is to inspect the pads even if they appear to have plenty of friction material left.
ChuckE.
ChuckE.
