Hi, got a Dana 70 rear. Changed fluid about a yr ago to valvoline synthetic 75 90. Drove fine until about two months ago, noticed that the rear wanted to slide on take off, (wet roads) at slow spds,low throttle, I drive it like a grandma on road. The other week was driving, again on wet roads, gave it throttle going up a slight grade and all heck broke loose, barely got back control of it, thank goodness nobody else was around. And this was by no means being agressive on the gas pedal. Done research in old posts, and am wondering if I need to go back to petro diff fluid? Also, increased the fueling(new injectors,new box) at about the time started having rear end issues. Truck hits 30ish boost too easy, about as high as I want to go on stock head.
