rear wheel lockup when wet
300,000 miles
test
I have began to notice after it rains the first time i step on the brakes, the drivers side rear wheel will lock up. I've had brakes lock up because of a wheel seal leaking, but never one that only did it after it rained. Usually, it does not do it if i drive it in rain, only if it sits for 6 hours or more and it rains on the truck. After the time using the brakes, everything is normal. Any suggestions for what to check?
Daniel McKeehan
1999 2500 QC/Short Bed/4X4 5 speed. Camper Package and of course a Cummins
My parents had a small pickup that would do the same thing. ie: put you through the wind shield the first time the brakes applied when wet. it did that for several brake shoe replacements and 125000 miles. Ive have had several Dodges and have not had that happen. might try a new set of shoes.
good luck
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, DD1's, EZ, DTT VB & TC, Westech Boost/EGT gage, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, quadrajet 4 barrel, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, RCI racing seats, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
My brakes do that too. The consensus opinion is that the shoes are to blame. I'm not going to worry about it. When I change the shoes, I hope it goes away.
1996 Dodge 2500 4X4 SC, SLT,Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, ATS 3-piece Exhaust Manifold, Chrome Valve Covers, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights. As of 5-19-01, 68,522 miles.
the problem is usually moisture sensitive shoes. if you can live with it it won't cause a problem. it usually goes away after the first few stops. otherwise change the shoes---the kicker is knowing what lining to use. ----Sam
We have a ton of trucks at work that this happens to. I got so P**sed off one day, I pulled the rear drum for a look without driving. There was surface rust, very thin on the drum. It would seem to me that after driving, the drums would heat up enough that after the truck was parked, water would condense on the drum surface. The first brake application after sitting would be the worst. Total grab. Big skidmarks etc. I found that if you could get enough speed,I could gently apply the brakes and "burnish the rust off" that my opinion any way.
01. 5 ETH/DEE QC, 2500 4X4, 3. 54 Everything but leather, added SPA Boost/EGT guage.
68 Jeep CJ5, V6, 225ci, sm420, warn overdrive, full floating detroit locked 44 in back,
2. 5" superlift, power steering, 4. 88gears. Mobiweld welder and other neat stuff.
A lot of owners adjust the rear drums by hand because the automatic adjusters don't work all that well. Maybe you should try that once. Mine lock up too but on both sides. If it is especially damp, I hold the brake on while heading down my driveway to dry them before I need them. Hate that jerking against the seatbelt.
maybe you guys have given me something to think about. . my 99 3500 EVERY morning after sitting all night will lock up the first 2 or 3 times the brakes are applied no matter how gently you apply them... jerks the heck out of your neck. slides the wheels. all four of them if not on pavement. [live in the country]... wife hates it. dealer says " gee we never heard of that"... it never ceases to amaze me all the things the dealers have NEVER heard of or had happen to any of the trucks they sell. absolutely amazing...
