Rear wheel well liners w/ Kelderman 4-link
leaky door seal
Spacers removal for lowering rear end
Anyone have this setup? I am thinking of adding the wheel well liners to clean things up in the rear wheel wells but in looking at the where the Kelderman parts sit, I'm not sure if the liners will fit in there. Wondering if anyone has done this or if I am going to order them and have to hack them up pretty good to get them to fit. Thanks!
I don't have the 4 Link, but I do have the liners. I would purchase them and then cut around anything that might hit.
I had the 5" lift 4 link kit on my 03 with wheel well liners, there were no clearance problems. I don't think you'll have a problem but would do as mentioned above, just cut around what doesn't clear.
The liners are right/left though, be sure you have them on the correct sides before you start cutting!
-Scott
Beleave it or not the factory one fit right on no modifying & thay were cheeper than other shops put them on in a few minutes.
Thanks to all and thanks Scott for the pic! That cleared it up... it looks like I might have to trim a little around the part that clamps on the axle as mine is setup with the 0" lift (standard kit with ground off bump stop mounts). My real concern was that the liner was too close to the frame rail to clear the air bag. Based on that pic, I have plenty of room.
Thanks again!
Just a quick follow up for anybody that might search this thread out, I got the liners put in (they make it look a lot cleaner!) and they fit without modification. I did end up cutting a small notch out where the axle top link bolt head is, fully aired down, it looked like it might catch on the bolt when dropping down, if you don't remove the bump stop blocks when installing the Kelderman kit I don't think you would have to cut them at all.
