Are you sure it's your lift pump making (sucking) air. I've seen the fuel heater, prefilter let air in around the heater electrical connector and NOT leak fuel. The prefilter, fuel heater is before the lift pump. The lift pump usually leaks fuel into the crank case or motor oil out the primer pump pin. Just giving another place to look Rhonda.
I was not sure but here's
the diagnosis: my truck seemed under-powered under throttle. As a test I flipped on my electric fuel pump (line goes from tank to injection pump) and power came back. This has been going on for some time now and getting worse. Figured it might be air-related, possibly around the lift pump (per reading here). Return hose under head has been replaced already.
Tore it down yesterday and
found the following: rust-colored bits and gooey stuff in pre-filter housing; pre-filter is black (they are white new); pump parts themselves look okay, but fuel inside was black with more gooey stuff and little bits of stuff. I believe at minimum I'm getting a fuel/oil exchange from block.
I did the (permanent) heater removal and cleanup, and put assembly back together with new filter/gasket. Easy per instructions. I will use my other pump now with a new elbow hose between. Too bad there's not a "rebuild kit" for these things...
Note on work: I went in from the top, removing air horn, fuel filter, and afc housing, and bungy-ing the wiring harness out of the way (disconnect plug from bottom of head as well). It's pretty open if you do that. I'm putting in a new fuel filter too.
Issues: Napa only has the round O-rings - stock ones seem to be coated metal, thin and flat. I found a stiff rubber type at a hydraulic company called "backup rings" which I tried. They don't work. They bulge like any rubber will in this application. I don't know if there's a slightly different pump than my two, but perhaps injection-related washers are required. (I have edited this now that I tried them)
Also had to go to Tacoma Screw for the proper sized studs that replace the bolts mounting the unit to the block. Those should make re-mounting much easier!
I've been taking pictures and will post after I'm done.
Question: if I want to have my oil tested, where do I go?
Thanks for the support!
