removing stock decals plates
Skyjacker Double Flex Control Arms
Buckstop front bumper on!
Use fishing line or dental floss and saw it off by running the line between the metal and the badge. The badges are stuck on with 2 sided tape. I took mine off that way and used WD40 as a solvent to remove the sticky stuff.
Did the same and used 3M adhesive remover. Wash and wax done.
GAmes. I bet you get the ol' "double take" all the time.
Garrett
i'd like to do it... but i have black that has 80k+ miles on it. does anyone know of anything i can do to "blend" the color? very fine sandpaper?
Tom
Be careful with the heat gun, I overheated mine a little and the chrome plastic coating started to delaminate / bubble. Now I've got to get another Cummins "C" one from Genos!
98rammer
Mine had 150,000 when I did mine and the Texas sun does have its effect. I used polishing compound and if you look real hard you can see where it was but a casual look doesnt pick it up.
be careful with the heat gun on anything plastic you intend on reusing or giving away, etc. works great if you just want the emblem off your truck, though.
___________________________________________________
Posted by Seed Guy. If you soak our badges in acetone like the ford ones do they come up compleatly chrome?
____________________________________________________
I would think if you soak those plastic badges in acetone that in a few minutes you would just have contaminated acetone.
ndurbin :
Thanks for the reply, I was curious because I was looking for a set that someone was taking off their 03, for a project.
Stick
