Set parking brake
Disconnect negative battery cables on both batteries
Turn ignition key to run (to drain any remaining capacitors)
Let truck sit for 30 minutes (this is the recommended minimum)
Return ignition to OFF position
Reconnect both batteries and secure.
Turn key to run position(do not start) and depress accelerator pedal slowly all the way to the floor
Allow pedal to return to top position slowly
Turn ignition switch OFF
Release parking brake
