Change L35 20 BR/YL (8W-50-9) Pin 87 and Pin 85 wires (or S183 in PDC) of Fog Lamp Relay to chassis ground.
Change L3 18 RD/OR (8W-50-9) Pin 86 wire of Fog Lamp Relay to Joint Connector #8 (8W-80-48), CAV 17 (if you do NOT have heated seats); fused ignition switch output (run).
Use second relay in combination with parking brake switch to turn off fog lights when ignition is on.
The fog lamp indicator will let you know when DRL is working.
re: 2001 ETH/DEE and service manual supplement.
