^^^You two need to get together at a some random Flying J and have "to the death" purse fight.....
I let my 68RFE drain overnight - I think I drained ~1 quart over that 14 hr period. Gave me time to gather thoughts and start fresh in the morning anyway. For me, Geno's or Rockauto.
There is no way the converter would drain all the fluid out of it without removing it and pumping it out. If the converter has a drain plug on it you could also drain it that way, but I don't think the 68RFE converter has one.I'm too wild about letting an auto transmission drain for that long and here's why;
You start a vehicle with an auto in it, and if the torque converter isn't filled, you can say good bye to it and, most probably, your transmission.
Now, I could be completely off-base here, and I often am, but I just don't like the idea of my TC losing full capacity. Maybe it doesn't and I'm just imagining things.
Wouldn't be the first time
Have done this exact procedure on my rig with no issues! Was able to replace 12 -13 quarts of fluid. I also added drain plug on pan to drain the couple quarts left in pan to avoid the mess and allow me to add temp sensor in the future. Back flushing with machine would allow more fluid exchange but don't like leaving the filters unchanged. Used the Super Tech fluid. All fluids are made to meet the specs required. Also been using the Super Tech DEF without any issues! Save some $$$ to using on other toys or "jewelry" for your trucks!Here is a reprint from TDR Issue 64 that explains how to change the transmission fluid and get the "majority" of the fluid changed. http://cdn.genosgarage.com/downloads/TechPDF/TDR64_TransFluidChange.pdf
So.....does this mean it’s still just a partial fluid change after all?This is an easy way to get "NEARLY ALL" old fluid removed.
I don’t tell anyone what to use or what to do.
it’s very easy to do a fluid exchange on the 68.
I am hesitant to say anything cuz I get so much chitz for even mentioning changing “all” the fluid.
If you want to know how to do it pm me. Not worth the criticism to say how on here.
At a trans shop that has a fluid exchange machine.Not sure how to pm. I would like to know how to do a complete fluid change on my 68RFE.
Thank you!
Was hoping to do myself. Yes I bought 15l of transmission fluid. Just not sure how to get the old stuff out.At a trans shop that has a fluid exchange machine.
DIY at home takes lots of extra trans fluid to flush all the old out.
