I have a 1999 2500 quad 4x4 driftwood in color. Has anybody experienced rust from the inside bottom of driver door. This started from the inside of the door panel where the steel is rolled under. I also have a lot of rust under the truck. When I had the injector pump replaced the mechanic said the engine looked like it had been in a fire the engine is rusting and peeling. Also wanted to know if somebody has a contact name & number directly for a dodge rep. Have taken it to local dealer twice and they say manufacturer denies warranty claim. If somebody has had the same problem were you able to get dodge to fix the problem. The rust on the door is very bad and getting more noticeable.
Thanks
Mark
Thanks
Mark
