RV Levelers
Happy Thanksgiving
Fuel Mileage and truck Campers
Not sure what to think about this, seems like a good idea. Check out www.Level-Air.com, they are air bags that you use to level your rv from side to side. Says they are rated at 12,000 lbs each at a max. of 50 psi. Seems that your rv would be bouncing all over the place.
Pump up a bag, or stack blocks and drive up onto them.
Seems like 6 one way, half dozen the other. However you can keep stacking blocks. Seems like the bag would have a limited leveling range.
The big advantage of the bags is you put them under the tires empty, of course, and pump them up to you desired level. One time. With blocks or wood, well, you know the routine.
And the bags go to 3 inches.
. . Preston. .
. . Preston. .
Then put the bags on top of the blocks! I would hate to start that far off level to begin with.
Harold
D&D... ..... seems you haven't been to very many races. Most times you got what you got. But the intent here is not to promote the bags. If you don't like the idea, don't use um.
