My Son Just bought a used 2015 , CTD 2500 4x4 . Any body got this message before? There is no engine light, and no stored messages. It comes on during driving and after a while goes back off by itself.
The truck has 70k kilometres or around 50k miles....
2018 Ram 3500 Turbo diesel 30k miles
On 4/16/19
Filled up DEF tank. 100 miles later Message appears
SERVICE DEF SEE DEALER
Countdown begins 150
At 40 check engine like.
I go to dealer. P207 code. DEF QUALITY
they reset. I’m on my way.
30 miles later message appears again.
Countdown begins 40 miles to go max speed 5MPG
I call dealer. He says you’re gonna need a new tank.
I ask if I can clean the tank. He INSISTS I need new tank. Back order 2 weeks. Common issue.
INSTEAD i go under truck. Unplug all plugs related to DEF near DEF tank. Clean them.
I unhook the DEF hose that goes into tank. ( the thicker one ) siphon the old def out. ( bought a siphon pump. Didn’t need the pump. All I did was stick the hose the cane with the pump inside the tank and watched the DEF pour out. So any hose might suffice. )
Connected everything back.
Refilled with PEAK DEF 2.5 gallons. Didn’t fill all the way.
PROBLEM SOLVED!!!
