Question: I have a 95 3/4 Ton that can pull 16,000#. The 2004 Dually 1 ton can pull 16,000#. What would be the advantage of a dually over a single? Advise.
Question: Problem with the 2004 1 ton dually --it stands from ground to top bed rail at 59". The 2004 1 ton single rear wheel stands from ground to top bed rail at 57 1/2". What gives with Dodge going to this height between single wheel and duallies? Problems for gooseneck haulers - crunching the bed rail because it doesn't have enough clearance? By the way I haul dogs and horses with a 39 foot LQ slant load trailer.
Question: Do I have to go to a Ford or Chev, because they keep the height down to 53-56" or try a single wheel instead of a dually? Is stability a factor? Is safety a factor, or is it just an appearance or cool look thing?
