I just installed a DT trackbar, the longer DT upper & lower control arms, a set of Skyjacker D25 coils with Procomp ES3000 shocks, along with a full set of tierod ends. Now the front end sits higher then the rear. Will these coils settle down some? I'm just wondering if I should raise the rear 2", since its going to a spring shop for an alignment and an inspection. Will 35" tires fit under my truck now?
PS. What would be the easiest way to pass the snap test, Slide the AFC back?
Sean
Sean
