Engine/Transmission (1998.5 - 2002) Slipping con-ofe
2nd Gen Non-Engine/Transmission MiniComputer Temp failure
Engine/Transmission (1994 - 1998) FASS installed on 12 Valve
Have a Con-ofe with less than 4000 miles on it. recently stacked the truck with a smarty. on sw9 plus TST on 4 the truck lost power but the rpm's hit 3500. I dont know what my dyno numbers are with out the smarty the truck with TST on 9 is around 460-470 hp. I never run the truck that high. does the Con-ofe recover well after slipping. I think I should be able to run smarty sw9 and up to TST 4 I think. anyone else have the same bombs maybe can chime in on some dino numbers. Thanks
2002 HO 6-SPD LB 4X4 QC 4" SILVERLINE PYRO, BOOST,FUEL GAUGES, HTT 62/14 CON-OFE TST PWRMAX 3,/ SMARTY 100/JAMMERS AFE STAGE 2
TURN-OVER BALL, RIDE RITE AIR BAGS. FASS 95/FLOW PUMP, VULCAN 3/8 FUEL LINE AND FITTINGS, FUEL PRESSURE GAUGE, DSS 03 TRAC-BAR 17'' KMC BLACK HOSS, 305/70/17 PRO-COMP X-AT'S COUPLE OF STUPID STICKERS AND DE-BADGED FOR FUEL MILEAGE.
With the mods in my sig I put down 406hp/948tq with the TST on 5 above that from 6-9 the hp stayed the same tq went up slightly.
anyone else help with dino numbers that are close to what I have in my sig. trying to find out what combo the con-ofe will handle. tst on what number and smarty
thanks
Call Peter at Southbend, hes the one to speak to. Plus if there is anythimg wrong with the clutch he will stand behind it.
