Smarty jr
What are you doing to your new 6.7
Can the dealer "LocK" the OBD port..
I looked at their site but I didn't see the info. Can this tuner be used on an
'11 without deletes? Or do we have to delete to use any tuner?
11 is in final testing now. On all others the ME version is for detetes, the others are for stock. You can buy the regular version, then later do deletes and do. wnload the ME version
The Smarty JR and The Smarty S-67 both can be used without deletes. You need to download the ME version of the software if you do the deletes.
The programmer will still leave a foot print in the ECM regardless of the software you use with the 6. 7L engine.
Jim W.
Will the unit for the 11' also work on the 2011. 5 H. O. (800ft/tq) truck?
I don't need any more power power, I'm just looking for EGR and DPF options. Would also like to fix the lag in throttle response.
-Thanks
with as much testing as they are doing to make sure they cover all the differences between 10 and 11 I am sure the HO will require its own testing before they release it for them, but I am sure its coming. I amstill waiting for official release of the 11, but it has been interesting to read posts on some of the other forums by the testers, and seen dyno tests and read seat of the pants reviews by people not involved with the company. Only drawback seems to be on all the newer trucks they cannot seem to make it invisable. When a dealer plugs into your obd port, they can tell you did something, even if you put stock specs back in , therefore SOME dealers may try to void warrenty.
