RCenters said:my fuel system is 160 GPH pump 1/2 line to the VP and i run 22 psi
I seem to remember reading somewhere that Cummins recomended no more than 17 psi MAX for a VP 44. If this is true, you may be blowing the pressure relief valve.
Walt-L said:I seem to remember reading somewhere that Cummins recomended no more than 17 psi MAX for a VP 44. If this is true, you may be blowing the pressure relief valve.
NoSeeUm said:Overflow valve?
Jim
The overflow valve is on the side of the VP44. It looks like a banjo bolt and has a return line attached that goes to the back of the block. It's easily removed with a 19MM wrench.
The overflow does not lower pressure at the front of the VP. I have had mine open to atmosphere and I can still maintain 20 psi. The way I think of it is a means to hold some fuel in the body of the VP at all times. It is not a pressure regulator like in a gasser. The fuel still enters the front of the pump and that's where the wear would be.
RCenters said:I know were yr talking about , its beside the supply bango or fitting am i wright ? So i can just take that out ? iv had that of alot last few days swaping pumps i didnt c no such valve ? is it inside mayb ?? i really need a pic hehehe
The sublevels don't do anything without the pump wire tapped.
That is quite my understanding. Without the tap the sublevels effect weither stock fueling is delayed 1-2, normal 3 or sooner 4-5. I set my untapped Comp for:
1x1
2x2
3x3
4x4
5x5
So, depending on the main level selected, I am effecting the sublevel. On 5x5 it will make smoke easier than on 3x3 where I normally leave it. SNOKING
Fishin Guide said:I can maintain 20 psi with the overflow valve out and vented to atmosphere. So, if the valve is in constant bypass, the VP is not retaining any fuel internally. The fuel pressure that we all see is resistance to flow at the snout of the pump.
So again, I would do the FREE check of the overflow valve. I have 20 PSI showing all the time and whent he overflow went bad, the driveability sucked.
Do what you will with the information. if it checks out, then fine. At leasst you have ruled it out.
Dave
DLBurns said:My driveability is fine without the fiver hooked up. I have been running around all over Seaside and Astoria unloaded and have not had a "huffing" issue yet![]()
I will look into the overflow issue when I get home.
I do appreciate your responses...
Dave
I got my AEM air filter today that I installed onto the AFE stage 2 air box so I took the truck out to see if it would build the same boost and to see if the temps moved from the AFE filter. I was getting on it pretty hard getting onto the freeway (out of town), got on the freeway and slowed down to 75 and was just cruizing along until I got behind an RV so I pull into the left lane to pass him but the truck doesn't do anything when I give it throttle, I tried severall times of letting off then pressing again but nothing. Finally after letting off and back on it responds and I wipe the sweat from my brow. When I got home I grabbed the Smarty and checked the codes (CEL never came on), the Smarty reported P0216 - Fuel Injection Pump Timing Failure, P0602 ECM Fueling Calibration Error: Common With Non-Stock Software and a P1693 - DTC Detected in Companion JTEC Module.
Am I screwed?
Another question how does the ECM know I am not running stock software? Is this P0216 code common with all trucks running Catchers or Smarties?
(Later by same guy, in same thread):
My F/P is at 13 idle 11 normal driving but I can suck it down to about 5 WOT. I have been using Power Service double dose on almost every fill since new and the truck has 27k on it now. I'm pretty sure its not the Smarty thats the problem but this does bring up an interesting point. I'm pretty sure the only way I can get it to show the P0216 is with the Smarty and drive it really hard but in doing so it also sets off the other codes. Is there any way I can reset the other codes but leave the P0216 and then put the Smarty back to stock and take it back to the dealer with just the P0216 showing so they don't know I'm running with different software? I'm still under warranty and would like to get them to fix it. Has anyone had any problems with dealers giving them a hard time with gauges and an intake but nothing else?
Bob Wagner said:I can push my truck to 3500 and never set a 0216 code with either the catcher ecm or now the smarty.
I do believe smarty will show a weak vp44 ready to go out
Bob Wagner said:Gary, Cummin on the nw bomber board did get the 0216 to set while smarty was off the truck and he was pulling his 5er on a hill.
the dealer replaced the pump and also gave cummin a new in the tank lift pump :{
