Squeak While Turning Cured
Check Engine Light & Tach Problems
transmission Fluid Question
Shelby Griggs
I took my truck in for the clock spring recall today, and asked them to attempt a repair on my squeak that occurred while turning and hitting a bump, crack, etc. This squeak has been described and remedies suggested in several threads here on the TDR;
Dash Squeak
Squeak in Front End While Turning???
Squeeky steering wheel help :)
Steering Wheel woes :(
Squeak in dash--sometimes
They did the clock spring recall in under 30 minutes, guess they are in practice, even showed me the old one, not exactly what I had envisioned. The service writer at first told me no squeak found, but I happened to talk to the tech on the way to the service area to get my truck. As soon as I described the squeak to him, he immediately said sounds like an intermediate steering shaft, and went to check to see if they had one in stock. They did, and he installed without any test drive or further questioning. That fixed the squeak, and he told me it IS the upper u-joint, just as has been reported here. If you are still under warranty, I would take it in for the replacement. The bad news is, I think it is the same old shaft, so I expect the squeak to return eventually, but knowing it is the upper joint, I can always lube. Mine had this since day one, so maybe they either squeak or they don't???
I give 5 stars to TS&S in Bend, OR for this fix. Credit where it is due. I have had mixed results there before, but I think they are really trying hard to please the customer.
The tech that fixed the shaft (not sure if he put the clock spring in or not) just happens to own a 2001 ETH/DEE truck built within a week or two of mine, super cool :) . While he was putting the shaft in we had a good chat. Found out he only lives about 1/2 mile from me. I encouraged him to join the TDR, but his buddy is a member (I have no idea who that is) and he looks at the site and his buddy lets him read the magazine.
We chatted about wandering, stiff shifting 6 speeds, lift pumps, fuel senders, etc. , you know the stuff we chat about all the time. He was aware of bigger fuel line solutions, parallel or booster lift pumps, etc. He claims that except for the pump which would be there on a FI gasser, the mounting, etc. is present on our diesel fuel sender modules. I know the FI pumps are too high of pressure, but it seems to me that DC ought to step up to the plate and retrofit a low pressure pump onto the existing module. That would be a clean in the tank install that would cure the current lift pump woes for good. He thinks the present lift pump location (far from the tank) is because the lift pump is part of the motor from Cummins, and DC didn't want to mess with relocating it. BTW, he highly recommends a FP gauge. I gotta do that soon :eek:.
Anyway, very good conversation, glad to know there is some good dealer personnel out there, after hearing all of the bad reports.
Shelby
Glad the pita stuff is fixed.
just a note. I had a in the tank low pressure pump fail on a F-rd . They use a hi volume low pres transfer pump to supply a low vol high pressure pump. You could not replace it w/ out dropping the fuel tank. :mad:
How does that compare with a 1 hr on the side of the road repair ???? for a stock or relocated near the tank pump. :cool:
Shelby, it always seems to make a difference, no, make that a big difference when the guy working on your Ram also owns (a Cummins powered) one.
Thanks for the info. Shelby. Ill head down to my dealer here and tell them to replace that. I have a bout 1000 miles left on warranty. If they dont fix it I guess I will head to TS&S in Bend. Actually I may heading up on Sunday for a 3 day river trip.
Shelby - hope you signed up for the Timberline TDR! C U there, I reckon. Going to trailer up on Thursday and be staying in Pacific City.
Man this is just one more reason that I am so glad I joined the TDR... . I've noticed a squeak in my truck the last few days when I was hitting bumps while the wheel was turned. I figured it was coming from under the dash and wasn't looking forward to trying to find it. My truck is going to the dealer on Monday to try and find out why the cruise control doesn't disengage when you step on the clutch pedal-I'm going to have them check out the intermediate shaft.
Thanks again for sharing experiences to help the rest of us out.
Jason
