Stalls when put in drive??
propane
Pump & Injector questions
Has anyone experienced a stalling problem when you've put your truck in gear? It doesn't matter warm or cold, it's an intermittent problem that may occur at any time. It may go for weeks at a time without acting up. Upon occurrence restart is immediate. ???
Crazy Horse, It seems to me your problem is your lift pump. We have had that trouble quite a bit and when you check the pressure at the filter port it is usually 0. Usually you have this problem with a set of injectors or a fueling box we've had the problem with both. The Lift pumps on these trucks do not run well on stock trucks more less modified ones. If it's under warranty take it in. And if you've heard of how these trucks defuel ususally in 99 avoid from doing it... IT WILL EAT YOUR POOR LITTLE VP44, we've had that done also. So there is my two cents worth, Blackdog is about to put a Holley lift pump on his truck it has a external regulator to regulate the psi to 15 or so. Be Good.
1994 2500 Regular Cab Longbed, 4x4 Red & Silver, Stainless Steel Rocker Panels, 2. 5" Skyjacker, tweaked afc & pump, BIG plate, HX35 w/16cm housing,no muffler or resonator, 16. 5x9. 75 Weld Rims, 33x12. 50 BFG Mud Terrians, 60 psi boost gauge, pryometer, J&J Stainless Steel rear 10" drop bumper w/backup lights, Westin pushbar, PIAA 90 Pro series lights, Weatherguard toolbox 27", Aluminum bed rails & tailgate protector, President Lincoln H. A. M. radio converted, 400 watt linear, Premier Pioneer stereo, *COMING SOON* 370 hp injectors,
crazy horse , what year , i remeber hearing about a TSB for this problem , check fritz's site . a reflash is in order for it , but also check your lift pump pressure .
Crazy Horse - Hello from Anchorage. I had this problem and the Anchorage dealer knows about it. They reflashed my truck with 18-015-00 Rev A. This fixed the problem of stalling when I put the truck in gear.
My truck stalled every time I put it in to drive or reverse, after the reflash it does not stall at all.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Guard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DTT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. Fuel Pressure gauge, SS fuel lines and lift pump relocation on deck. See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
I am my own warranty station.
Mopar Muscle it's a 2000 w/ auto trans,354's.
JR2 it's good to see someone else posting from Alaska.
[This message has been edited by Crazy Horse (edited 05-18-2001). ]
