Here is the write up with pictures that I promised. Many know I haven't had heater grids all winter, and I've only been procrastinating on getting this done as well.
Anyways I ordered two Stanco Relays #120-902 from Allied Electronics last week. Phone #1-800-433-5700. Total came to $35 shipping and all..... 1/2! the cost of the factory pieces.
I did the following while following directions of a past post made by JoeBioDiesel.
First thing I did was remove the battery & intake horn and tie the intercooler tube up away for a little more elbow room.
Three sheet 10MM sheet metal screws are all that holds the bracket in place. Just simply disconnect the 4 small push on contectors, and unbolt the 4 13mm nuts holding the pos. cables on. Here's the old relays and mount
Here's a side by side comparaison. The new Stanco's are a lot more beefier.
Simply push the tabs back holding the old relays on and they will fall right off.
Next cut the tabs off with some wire cutters, and grind the remains off. You may have to grind a little more too to fit the relays over the bracket. We did.
Hold the new relays in place with the indention on the back of the relay in the indention in the bracket, and fold the brackets back around the OEM mount.
Here's a top view of the new relays on the OEM mount.
Here's the mount reinstalled... .
NOW I HAVE HEATER GRIDS! Oo.
