Starter or Safety switch on clutch
New truck in 40 Days
Oil Temp. Sender placement
At times I get a loud click when I try to start up. sometimes once and then it starts, sometimes 4 or 5 times and then it starts.
Does it cold or warm. Any Ideas. You may email me direct if you wish.
95 3/4 4x4 5 Spd K&N Air Filter 100,000
Ride Rite Air Overloads
10 1/2 Cabover Camper
[This message has been edited by Ray (edited 10-13-2000). ]
I wish I knew for sure that yours might have the same system. But here it goes anyway.
The safety switch on my clutch quit along time ago, 'bout 4 years, with the same symptoms. Pump the pedal and hope she catches. #ad
The replacement was not cheap, but not that hard to replace. For the life of me, can't remember the cost (didn't keep that reciept #ad
)around $100 Cdn.
Hope this helps
Lil' Mack - 89 D250LE 2WD 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
232,500 miles (372,000 Kms) 7700 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
[This message has been edited by Lil' Dog (edited 10-13-2000). ]
Ray I have a 95 also and solenoid on starter was worn giving me the same symptoms as you describe. I overhaul the solenoid and everything is OK now.
Parts are available $10. 00 cdn from electrical repair shops but not from dealer they only supply complete starter/solenoid assemblies.
Ray, Mello is right. My starter was doing the same thing. Rebuild the soleniod (simple), or get a rebuilt starter. I could be your neutral safety switch, but this is a common problem with the starters. The only solenoid rebuid kit I know of is from the address below.
Here is the address :
Diesel Electric Service Co. , Inc.
Casa Grande, Arizona
1-520-836-8231
Request the full rebuild kit for the Dodge w/Cummins Ram starter solenoid
[This message has been edited by HEMI®Dart (edited 10-13-2000). ]
Ray should be easy to by pass clutch switch to see if it is bad. I think service manual has instruction how to do this.
As I recall this switch is ground to starter relay when clutch pedal is pushed to floor.
I check batery, starter relay, clutch safety switch, soleniod, wires,connections, grounds.
2 Cents
Most likely a connection problem .
check all . And don't for get the strap from the solenoid to the starter . You would not be the First guy that replaced same,and had it been check & cleaned - reinstalled no parts would have been needed.
To Check the starter, pull it off (following all the proper procedures) and remove the end from the solenoid. If it is bad it will show! I couldn't get a parts kit and the local repair shop charged me 50! #ad
It's an easy fix and if you go far enough to check it, you are almost done fixing it.
'94 3500 4x4, 201,000 miles, Never had a cat, Auto w/shift kit (currently under remodification), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro gauges inplace of cupholder & Amsoil Bumper to Bumper. NRA member.
"Warrantee? We don't need no stinking warrantee!"
Thanks to all who replied to my request for information. Read them all plus all those from a while back. Checked all suggestions and ended up with a new starter. Works great now. #ad
