I had posted about this earlier this year when it was still cool out, and now that the cold has returned, so has my problems. When starting the truck in the morning, the heaters will cycle and when the switch is turned to the start position, the truck will start for about 2 seconds and kill. Eventually it will start and spit and sputter, but it does clear up and run fine then. Fuel milage hasn't dropped and power and performance seems the same. I pressurized the tank and found no leaks in any fuel lines, replaced the injectors, and installed a new lift pump. I've also put a jumper wire from the battery to the fuel solenoid and I can hear it click plain as day, but even with the jumper wire, it still won't start right away. I'm open to any ideas to try at this point. Any advice is much appreciated.
Dustin
Dustin
