You know I have had the Rancho steering stabilizer kits on several trucks and they are worked fine. But lately some companies have come out with a dual steering stabilizer that is in-line. This has be intrigued, and I think it would be much more effective. I have had dual kits before, they work but there is some binding and they are both always in ether compression or rebound. The in-line kit lays each one down, parallel to the axle and when one is in rebound the other is in compression, this seems like a better way to accomplish the mission. I have just ordered the Skyjacker in-line dual steering stabilizer from 4 Wheel Parts. I will let you know how it works after the install. Maybe this set-up isn't for you? But it sure seems to be the better way to go.
