Back to you Gregg.....
Gregg Mig said:
Hi Dave, the bushing you sent that was reamed once fit perfect! it took that little bit of play I had away, no more clunking feeling in the wheel. Now I just have a click or little pop occasionally when turning or even just leaning or putting pressure on the steering wheel. I have isolated it the the steering collum , the lower part that is behind the collapsible mesh, this is where the noise is coming from, the shaft fits into another shaft that is riveted together, this is were the clicking popping noise is coming from. The steering collum is telegraphing it thru the steering wheel. This is why the dealer replace the whole collum on my 97 ram, they said it was bad,why they did not do the same on my 02,I don't know. I just educated myself about this in the last couple of weeks,and have not seem anyone on this site mention it. Im going to remove the whole collum again soon cut a little of the collapsible mesh and try to braze it. If I cant do that I guess I will have to buy a new collum. I guess I should also tell everyone that one way of checking to see if your collum is junk is to turn the wheel back and forth with the engine off, if you feel clicking or popping then your collum is shot. Oh one last thing I drive a 6 speed manual so I think this applies to all dodge trucks models and years. Gregg
Ok now from what you say, that you're a manual trans model, a picture is forming in my head:
On the auto trucks, there is a tube type rotating structure that is made to give way for crash protection, that can break & cause either funny noises or non-operation of the shifting function. (This is what Prospector Tim fixed with a pop rivet a few dozen posts back on this thread... . )
On the manual trucks, (should be an easier fix... ) you - I'm making an educated guess here, have a shear pin or some sort of break-a-way rivet that must hold two pieces of the inner column as one. After many miles & years, this "shear pin" gets loose, and bingo, clunk , etc.
If you can dissasemble to get at it, it should be a pretty simple 'workbench' fix to secure it again. If you must, I think you can cut & repair the outer mesh (actually, slotted & collapsible metal outer column housing, if I may term it so).
For those who don't weld or braze, I bet either small sheet metal screws, industrial epoxy or similar would work to repair, if you must cut it.
Doing so may provide the only access to the two part inner column shaft that we strongly suspect is coming loose. I wonder if you could use a good flashlight, and observe while someone moves the steering wheel ?
Please update us on your efforts, Gregg !
Nice to hear from you. You're a few steps closer to that perfect steering feel.....
David B.
