Stering pull
Reposition windshield wiper
abs and brake idiot lights
I have a stock 04 with the same type tires it came with. The u-joints and tie rods have been replaced.
Here is the problem. When exiting the interstate, at any speed, the steering tugs or pulls to the left. So you get a see saw movement.
Thanks
Try rotating your tires I had a slight pull to right on my truck when I bought the truck so I rotated the tires and the pull stopped check tire PSI. if low could pull or check your ball joints Dodges have been known for short ball joint life.
