Stock fuel filter screw on cover
Code P0088– No running issues
Intermittent light surge at hiway speeds.
Sounds like o-ring got nicked on the filter change. If cap was installed and tightened, it shouldn't back off at all. The o-ring not only seals but helps like a lock washer. Hope you can find out what caused it to loosen up on you.
As fine as the threads are I doubted it possible? It did start to leak and has about 10,000 miles on filter. I must have turned it 3/4 of a turn till it got tight. Haven't driven truck since. I am going to go ahead and change the filter and look at the cover real close. Thanks for the replies.
Well, I changed the filter, put cap on and tightened as tight I thought was good and I could still see the "O" ring, tightened some more, looks good. Guess I was fortunate it failed at home. (It didn't fail, I just failed to tighten it right the last time.) The filter housing is kind of like the low side port on the AC as far as access. With a little more engineering they both could have been made inaccessible.
