What is the stock timing set to from the factory? Secondly, what would you suggest for timing advance to make it run a little better with out frying anything. I have read around 15. 5 degrees advance but wanted some feedback before I had it done. I have marine injectors, stock pump with stock plate slid forward a little. Stock turbo (holes drilled in bottom of box, and cat. removed. thanks
