my e-brake cables are starting to stick. when i release the pedal the shoes arnt coming off the drums. the passenger side is the worst. the driver only sticks very rare. i can grab the cables and push them in and they will release. the passenger side one has a new cable too. and its the one sticking the worst? whats an easy fix for this.
also... when my rear alxe is raised, when the passenger side shoes where sticking, and the driver side wasnt, i could rotate the driverside wheel and the passenger side one wouldnt budge. is the limited slip supposed to do that? and... when both rear wheels are rotating, if i hold one steady the other will continue for maybe an inch? is this worn out gears?
and one more... whats too hot for rear axle to be? the bottom was not to hot to touch but if you kept your hand there for more than 15seconds it wasnt comfortable.
thanks yall.
thanks yall.
