Slybones,
Pressure is just a measure of flow restriction. Simple as that.
What emjay is describing is simple orifice flow. For any orifice or restriction to flow, the pressure drop across the orifice is dependant on the flow.
If you've ever shopped for spray nozzles for gardening or anything like that you would notice that the spray nozzles are rated at a certain pressure and flowrate. Like 2 GPM @ 60 psi.
So if you pump out two gallons per minute with this nozzle on the end of your hose, there will be 60 psi of pressure before the nozzle.
If you restrict the flow to where only 1 gallon per minute is pushed through the nozzle than only 40 psi or so will build before the nozzle.
So by pulsing a valve on and off you could lower the pressure delivered to the nozzle because you are lowering the flowrate.
The problem with that idea on our trannies, is the on/off valve to the torque converter (switch valve) isn't the same valve that the electrical wires hook to (lock up valve). And the electrical wires don't open and close the valve, they open and close a vent to the valve instead.
Also, once a clutch has sealed against the front cover, there is no more flow. It's completely sealed.
Minor problem for the pulse width idea. haha.
-Chris
